we bought a new Mikrotik CRS125-24G-1S recently. Very first one in the company so nobody knows anything. Basic setup and configuration are fine, we use PPPoE. Previously we had two Cisco routers but they didn’t work as expected (both had problems with WAN port) except one thing. Here my question/problem comes.
We use VPN, setup was smooth. We can access our network from outside so VPN itself works but we need one more thing to routing goes via local IP and not the VPN one. An example:
When I connect to our network I obtain such configuration from VPN
PPP adapter:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.10.100
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . :
192.168.10.0 255.255.255.0 192.168.10.1 192.168.10.100 36
But we would like to obtain such config:
192.168.0.0 255.255.255.0 192.168.10.1 192.168.10.100 36
Can Mikrotik return via VPN this IP 192.168.0.0/24 to be used for routing? This was possible on Cisco. And I haven’t found any way how to configure this on Mikrotik.
Thank you in advance for all your help. If you need any further info just let me know.
