Quick context: my ISP gives me a publicly routable IP, but blocks inbound packets on a few known privileged ports, like TCP 80 and TCP 443, on their “residential” plans, so to speak (for both security and commercial reasons, of course). I haven’t done a full diagnostics on every port over TCP and UDP, but the one affecting me the most is UDP 123 (which causes problems for NTP clients on Windows and RouterOS).
Given that, my NAT rules look something like this right now:
/ip firewall nat add action=masquerade chain=srcnat out-interface-list=wan-interface-list protocol=udp src-port=123 to-ports=49152-65535
/ipv6 firewall nat add action=src-nat chain=srcnat out-interface-list=wan-interface-list protocol=udp src-port=123 to-ports=49152-65535
Now, this seems to solve all problems that meet the eye. There may be some other application using source ports in the privileged range, but none causing any visible problems at the moment. (In the past, I did put some monitoring rules and I saw at least one case where an IoT device randomly used a source port 7xx over TCP, but I don’t remember observing any issues and that port probably was not blocked anyway)
Now here’s my main question: do source ports matter? Can’t I make all my NAT rules use source ports 1024-65535 and stop worrying about any other possible problems that might arise due to blocking on known privileged ports? Don’t CGNAT implementations already do this anyway? What is considered good practice regarding this? What if I do the following?
/ip firewall nat add action=masquerade chain=srcnat out-interface-list=wan-interface-list protocol=tcp to-ports=1024-65535
/ip firewall nat add action=masquerade chain=srcnat out-interface-list=wan-interface-list protocol=udp to-ports=1024-65535
/ipv6 firewall nat add action=src-nat chain=srcnat out-interface-list=wan-interface-list protocol=tcp to-ports=1024-65535
/ipv6 firewall nat add action=src-nat chain=srcnat out-interface-list=wan-interface-list protocol=udp to-ports=1024-65535
