Running 2.9.38 - other os/s also seem to work the same tried 2.9.34/29
After a 46degC day in Saturday when the Aircon in our comms room stopped along with the adjacent FM transmitter, we decided to replace a flakey sector Senao miniPCi AP with a new WRAP board with a SR2.
Our configuration is
WAN on Ether2
Hotspot on wlan1
PPPOE server on wlan2 Virtual AP
2xWDS links on WLAN1
This has worked ok before - but this is our first SR2.
The SR2 reports
int wir info print
0 interface-type=Atheros AR5213
chip-info="mac:0x5/0x9, phy:0x43, a5:0x46, a2:0x0, eeprom:0x4008"
pci-info="00:0d.0" capabilities=tx-power-control,ack-timeout-control,
virtual-ap,alignment-mode,noise-floor-
control,scanning,burst-support,nstreme,
sniffing,compression,power-channel
default-periodic-calibration=enabled...
1 interface-type=virtual-AP
so it thinks it can support a VAP.
IPs are assigned thus
ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 xxx.11.202.82/28 xxx.11.202.80 xxx.11.202.95 ether2
1 xxx.11.202.102/30 xxx.11.202.100 xxx.11.202.103 wds1
2 xxx.11.202.106/30 xxx.11.202.104 xxx.11.202.107 wds2
3 10.82.50.1/24 10.82.50.0 10.82.50.255 wlan1 (hotspot)
4 10.82.60.1/24 10.82.60.0 10.82.60.255 wlan2 (pppoe)
5 192.168.0.1/24 192.168.0.0 192.168.0.255 wlan1
The last three are pooled..
A pppoe-server server is assigned to VAP wlan2
With the VAP Wlan2 disabled then the WDS links work on wlan1
ping xxx.11.202.101
xxx.11.202.101 64 byte ping: ttl=64 time=26 ms
xxx.11.202.101 64 byte ping: ttl=64 time=19 ms
xxx.11.202.101 64 byte ping: ttl=64 time=4 ms
xxx.11.202.101 64 byte ping: ttl=64 time=98 ms
xxx.11.202.101 64 byte ping: ttl=64 time=10 ms
7 packets transmitted, 7 packets received, 0% packet los
for example.
Enable the VAP on wlan2
ping xxx.11.202.101 on wlan1
xxx.11.202.101 ping timeout
3 packets transmitted, 0 packets received, 100% packet loss
mode=ap-bridge ssid=xyzz area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2437 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=static
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
1 X name="wlan2" mtu=1500 mac-address=02:15:6D:53:31:D5 arp=enabled
disable-running-check=no interface-type=virtual-AP
master-interface=wlan1 ssid="abcdd" area="" max-station-count=2007
wds-mode=disabled wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no default-authentication=yes
default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=no
Any clue or is the card or os bad
Ken K.
