Do we have a list of how many devices
just want to ask do we have list for example
Hex model or other model, how many devices can connect and limit of devices can connect per models
Thanks in advance, I’m just new and trying to figure out what model would fit since on a tight budget
Current 2ISP ppoe 100Mbps and dynamic 200Mbps
estimate 50+ devices and doing a open vpn connection for like 3-4 users to connect to office
and a port forward a devices
Check RouterOS level which is assigned to device.
And then this page:
https://help.mikrotik.com/docs/display/ROS/RouterOS+license+keys
So if I bought any model I need also to buy license for it? or its already there?
Every HW you buy from Mikrotik, will already have a license.
For CHR you need to buy your own license.
hapax3 is your best budget approach, RB5009 is overkill but allows much room for growth.
