do you use ip firewall filter for bgp?
Hello
Did you enable firewall on your winbox service on your BGP Mikrotik router?
or you just set the known address?
From my understanding if we enabled the ip firewall filter, all the ipv4 fast path would not be utilised?
Hi! According to some vulnerability issues who are coming popular these days, I thing that configure some firewall rules at the input chain is a must, if not, you’re Mikrotik will be really easy to compromise using some exploits.
