Using the crs326 to get IP from ISP and then spread it around, requires NAT.
The following is something near a config which should do that.
Unfortunately, the default CRS routeros config is very poor for use as a router,
I have borrowed most of a default configuration especially the Firewall from a Mikrotik Hex router.
This has ether1 being the WAN interface, with DHCP client on it.
You would apply the config, section by section to the CRS. Ideally reviewing it before you apply it.
The config has an ipv6 firewall, At least initially I would apply the ipv6 firewall, but disable ipv6 on the device.
Then tweak to suit yourself.
Note: I am assuming the config is applied to a crs with near a default config (not empty) on it.
# Maybe CRS full firewall config.
add comment=defconf name=WAN
add comment=defconf name=LAN
** Remove ether1 from bridge, so it can be wan.
set [find where interface=ether1] disabled=yes
/ip dhcp-client
#likely already has this configured.
#/ip address
#add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add name=default-dhcp ranges=192.168.88.10-192.168.88.240
add address-pool=default-dhcp interface=bridge name=defconf
192.168.88.1
set allow-remote-requests=yes
established,related,untracked
invalid
## Default rule to block
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
#Optional but stuff I would recommend
#Leaves main access via winbox (there is mac telnet still)
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 settings
set disable-ipv6=yes
