Documentation for "name-format" under wifi provisioning
Hi!
I have been trying to find documentation for the “name-format” setting under provisioning when using capsman. I have seen examples on the forums were people are using %I to get the identity of the cap in the name, but what else is there? This page here AP Controller (CAPsMAN) - RouterOS - MikroTik Documentation seems very out of date for this setting specifically… Any help or information would be much appreciated!
What is missing there? As far as I see, all is documented:
See this section:
If included in the string, the character sequence %I will be replaced by the system identity of the cAP, %C will be replaced with the cAP’s TLS certificate’s Common Name, %R , or %r for lowercase, will be replaced with the CAP’s radio MAC Default: “cap-wifi”
Ah! Thank you! I just did not find that page!
You were looking in the wrong section of Help pages.
The one you referred to is for legacy wireless capsman.
The one Normis refers to is for wifi (wave2) capsman.
The documentation has now changed for a 3rd time and I still can't find the right page for this! Where is it on the new new new documentation?
