Ok, its working and then its doing it THING! all units flashes going crazy and generate max traffic every time a AP connects in and ask for WDS, this is really annoying…WDS’s come and go, the units are laying next to each other set on 20dBm
and every time a WDS connects in, the 1min+ long loop begins allll over again, basically, flooding the network with junk, and making it useless
its all set on rstp, how can I make the flood go away, or make it flood for a couple of seconds, instead of minutes?
every time a WDS link is made it is checking the throughput of the link so it could calculate the patch-cost of that link. You can minimize that by creating a connect-list rules to make WDS links only between the good stable links which will give you less WDS reconnects. Or you can disable the WDS automatic adding to the bridge ports and add the WDS interface manually to the bridge port with static patch-cost - in such case the WDS link will not check throughput and you will get more stable environment.
isnt there a way to make it ping all the other nodes and select the best ping instead of flooding the mesh for 2 minutes long constantly, its going to flood 80% of the time rendering the network useless ..?
uldis, I can’t implement your methods mate, its to much nodes and I run a risk to mess it up, because they all function as “repeaters”
…there has to be other options or script that just ping and select the best ping and make it root, I’ve got 4 units next to each other for testing and now and then, a WDS drops… impossible but yea.. its happens, and then its flood time all over again.
