Does anyone actually use the default configuration script ? I have have Grooves now that randomly half-reset themselves to this stupid script.
The pppoe is connected and wlan but can’t winbox, once I have mac-telnet I get this
The following default configuration has been installed on your router:
Wireless Configuration:
mode: station;
band: 2ghz-b/g/n;
frequency: 2412;
ht-chains: one;
ht-extension: 20/40mhz-ht-above;
WAN (gateway) Configuration:
gateway: wlan1 (renamed with extension ‘-gateway’);
firewall: enabled;
NAT: enabled;
DHCP Client: enabled;
LAN Configuration:
LAN Port: ether1-local;
LAN IP: 192.168.88.1;
DHCP Server: enabled;
