Does CapsMan work on 6.24
Where can i get CM2 package for ROS 6.24? WIll the 6.33.1 CM2 package work on 6.24?
THanks,
Second question first: “CAPsMAN v2 is working starting from RouterOS v6.22rc7”
http://wiki.mikrotik.com/wiki/Manual:CAPsMAN#Requirements
To download this package just enable the package in
/sys package
http://wiki.mikrotik.com/wiki/Manual:System/Packages#List_available_packages
Thank you for the reply. I will try when I am home tonight. CHeers
Time is over! :smiley: Did it work? (don’t forget to give kudo)
What will you buy for reputation points?
You dont’ want to be famous? :laughing: :smiley:
To be famous because of begging for kudos?
