I have a friend who is searching for a new switch and I recommended him this CRS112-8G-4S-IN switch, but he is in need for LACP. Does anyone know if the switch chip supports it or have someone tested it?
Thanks!
Thanks!
As i know on all of Mikrotiks you could confgiugre LACP but have a different name called Bounding.
http://wiki.mikrotik.com/wiki/Manual:Interface/Bonding
I have an CRS109-8G- 2HnD-IN … and i will double check and probably return with some pictures ..
Best Regards,
Daniel
Thank you for the answer.
The reason I’m asking is that I have this switch and I CAN NOT do LACP: http://routerboard.com/CRS226-24G-2SplusRM
The RouterOS absolutely supports it but the internal switch chip does not allow it.
There is something about a “Master Port” settings thats assigns physical ports to the internal switch chip. If I want to use a bonding interface I need to assign the bonding interface as a master port, and when I do that, the physical ports stops forwarding and receiving traffic.
pateutz:
Yurezplace:
Thanks!
Best Regards,
Daniel
The reason I’m asking is that I have this switch and I CAN NOT do LACP: http://routerboard.com/CRS226-24G-2SplusRMThe RouterOS absolutely supports it but the internal switch chip does not allow it.
Hi ,
this is a config on a mikrotik RB2011 …
Try to do the configuration as in picture.
I have not access yet to the CRS109-8G- 2HnD-IN yet but i will check .
Best Regards,
Daniel
Thank you for your reply. I look forward to hear from you later.
802.3ad compatible mode is currently not supported, please read more here
http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Trunking
Ok so mrz clarify the situation .
Sorry Yurezplace for the confusion . As you saw i have set up an LACP on a mikrotik but different product.
PS:
mrz probably in the feature will be a nice functionality of the product ![]()
Best Regards,
Daniel .
Ok, thank you for the link.
I will check it a couple of times per month to see when LACP support is added.
