Does hotspot work on RouterOS 7.20.2 ARM
Hi All,
Not sure if its something I’m doing, but I can not get a hotspot server to be “Valid” on a Mikrotik hAP ac² (RBD52G-5HacD2HnD-TC) running RouterOS 7.20.2
I backed up and restored the configuration to an older HaP (RB951Ui-2nD) running the same routerOS version (but a mipsbe processor) and it worked.
So the question,has anyone else experienced any issues with Hotspot on ARM based routerOS 7.20.2?
You may need to set the device into advanced mode. See here: Device-mode - RouterOS - MikroTik Documentation Not sure whether it is applicable to your hardware, but I had to do this on my L009 UiGS-RM with routeros 7.19.4
Thank you! This was the issue, once I enabled advanced mode and rebooted, hotspot was valid.
