I recently bought a Huawei E3372h 4G USB modem (Vendor ID 0x12d1 Device ID 0x157d) to use it with mAP2n router, but unfortunately it does not work. Maybe there will be a software upgrade solution/patch for this problem, but probably a faster solution at the moment is to to buy another model.
(I have connected to E3372 through Serial and sent AT SETPORT command to disable HiLink mode and use the regular modem mode. I can read the current value, but it won’t let me change the value and gives ERROR.)
I have a choice to buy E303 or E173 but before I do, I would like to ask if anyone has used either of these and will the work out of the box without any hacking ?
E3372 with Vendor ID 0x12d1 Device ID 0x157d have mbim interface we will support mbim in v7
you could tru to flesh different firmware that have vendor-id=“0x12d1” device-id=“0x14dc”
then it will work it using ECM driver
I am not sure about E303 it uses ECM but would it be possible to add support for this modem, i don’t know.
E173 should work using serial ppp-out interface
Do you mean that it doesn’t work as a LTE nor as a ppp-client interface?
It does not work in LTE and it also does not work as a ppp-client. That is why I am trying to disable Hilink mode, to get it to work as ppp-client.
Where could I find the firmware? It is not available on huawei’s site.
I will try to return the device, but because it works just fine when connected to the computer, I am not sure they will take it back.
Alright, I got my hands on E303 (Vendor ID 0x12d1, Device ID 0x1506) and also E173 (Vendor ID 0x12d1, Device ID 0x140c). I tried them both and can confirm that they work.
I have Huawei E3372 (Vendor ID 0x12d1)(Device ID 0x157d) and cant get the LTE interface.
i have restarted and rebooted every way possible and i have the latest 6.30.2 OS on RB2011UAS-2HnD
I have an E3372h-153 (T-mobile Hungary) modem, which did not work at first because of the need of usb modeswitch.
I could fix the problem using the AT^SETPORT command.
The original mode was:
AT^SETPORT=“A1,A2;12,1,16,A1,A2”
I set the modem to:
AT^SETPORT=“FF;12,1,16”
usb power reset, and it started working as a PPP interface.
I found theese settings using AT^SETPORT, and AT^GETPORTNAME:
AT^SETPORT=“initial_mode;normal_mode”
map:
1 - Mobile Data Modem (MDM)
5 - GPS interface
6 - control interface
12 - PC UI
10 - modem?
16 - NDIS
A1 - Virtual cd
A2 - TF card reader
FF - Dummy (disable modeswitch setting this to the initial mode?)
Hello sir, can you help me, I have E355 and stops working after 5mins unless you reboot router, the connection hangs, even to login to Mikrotik base box 2 become difficult.
Mine E3372h is working well with RouterOS after flashing it to a HiLink mode. I have a LTE interface appearing, and after getting DHCP address from modem’s internal router I have access to the Internet.
Im Rangga from Indonesia.. i have 4G LTE Huawei modem E3372, but it dont work in Mikrotik router RB951G-2HnD, the router can’t found LTE interface of modem..
can u help me please ?
tell me how to flashing my modem into a HiLink mode
