Hello there…
I have been using MT 2.9.29 for several days. Does my queue work if I use it with web proxy running?
Thank you in advance for a nice reply
Regards
Titok
Hello there…
Regards
Titok
yes, but you have set apropriate mangle and chain accordingly.
Bung Valens..,
***My mangle settings are (I try to limit IIX connection which I already list in /ip firewall address-list (around 2000 and more):
[raihan@MikroTik] ip firewall mangle> print
0 chain=prerouting src-address=192.168.1.3 dst-address-list=iix
action=mark-connection new-connection-mark=IIX-KomBack-Con
passthrough=yes
1 chain=prerouting connection-mark=IIX-KomBack-Con action=mark-packet
new-packet-mark=IIX-KomBack-Pack passthrough=yes
***and my queue lists are:
[raihan@MikroTik] queue tree> print
0 name="IIX-KomBack" parent=Dalam packet-mark=IIX-KomBack-Pack limit-at=0
queue=default priority=8 max-limit=64000 burst-limit=0 burst-threshold=0
burst-time=0s
***These settings would be fine if I am not enable web proxy…, but when I did enabled it, my queue will not work anymore… Anyway my web proxy settings are:
0 chain=srcnat out-interface=Luar src-address=192.168.1.0/24
action=masquerade
1 chain=dstnat in-interface=Dalam dst-address=!192.168.1.1 protocol=tcp
dst-port=80 action=redirect to-ports=3128
*** and like this:
[raihan@MikroTik] > ip proxy
[raihan@MikroTik] ip proxy> print
enabled: yes
src-address: 0.0.0.0
port: 3128
parent-proxy: 0.0.0.0:0
cache-drive: system
cache-administrator: "webmaster"
max-disk-cache-size: 17273000KiB
max-ram-cache-size: 35606KiB
cache-only-on-disk: yes
maximal-client-connections: 1000
maximal-server-connections: 1000
max-object-size: 51200KiB
max-fresh-time: 3d
If those web proxy settings are enabled, it seems my queue doesn’t work anymore, but if they were disabled, my queue is working… What’s wrong here??
Thank you in advance for any help…
Regards,
Tito
@ boss Valens
it’s seem not work for me too since 2.7.14
@bung Titok
add more MT box running in transparent shaping ![]()
try this code
Code:
action=masquerade
1 chain=dstnat in-interface=Dalam dst-address=!192.168.1.0/24 protocol=tcp dst-port=80 action=redirect to-ports=3128
note: !192.168.1.0/24
this will be one of the unsolved issues in MT , we are waiting for a new version of the manual to put some official examples , coz we see many ways made by users , and there is no proofing ..
note : even in MUM they ignore this issue !!! ![]()
Valens,
Nice one! This issue has bugged me for quite a while. will give this a shot!
Sonny.
