Does Mikrotik do PSPF = blocking all inter-client traffic?
If so, where is it using winbox?
Thanks!
John
Thanks!
John
It would be a nice Feature. Something like protected port on WDS.
Let’s wait for MT Team reply
Have you tried this
/interface wireless set wlan1 default-forwarding=no
AFAIK, you can try one more method.
Suppose you have configured 192.168.1.1/24 on LAN(Wireless Interface)
Now, the trick is to do this.
add action=drop chain=input comment="" disabled=no dst-address=192.168.1.2-192.168.1.254 in-interface=wlan1 src-address=192.168.1.2-192.168.1.254
add action=drop chain=output comment="" disabled=no dst-address=192.168.1.2-192.168.1.254 out-interface=wlan1 src-address=192.168.1.2-192.168.1.254
Is there a way to do any of this via Winbox?
Thanks!
John
Yes you can do both options via Winbox.
In IP > Firewall > Filter add a rule as mentioned.
Secondly, if you want to disable default Forwarding then click on interface then dbl click on wlan 1, go to wireless in the bottom there is a check box to disable default forwarding.
