does mikrotik support combining???
hi all ,
it’s just a dream … i read about combining two internet connection to get one with double speed but all i got is load balance
so any body have any information about if we can combine connection??
There are few ways possible, how you can combine two Internet connections to get one,
http://wiki.mikrotik.com/wiki/Routing
thanks alot
but does this ways do like the pics i attatched next???
same que !
i searched alot all we have is load balance ( i think it does not support combination )
Multiple gateway simple failover
Multiple gateway failover with load balancing
Improved Load Balancing over Multiple Gateways with Persistent Sessions
is there any one how can tell us if it’s possible ???
you just said that you read all those articles. still nothing? maybe you should hire a consultant that will do it for you? we have instructions how to do bonding and load balancing. you have to read the manual to understand how to use them
