A simple question… I am trying to set up an openvpn but all the openvpns i can find support sha256/512. It seems that because of its vulnerability sha1 is avoided/not used anymore and if Mikrotik can’t support sha256/512 then openvpn is simply not an option for me. Can anyone help? Thank you in advance.
Unfortunately for you and many others, MikroTik’s support for OpenVPN was always lacking and continues to do so.
Edit: 7.2rc1 has sha256 and sha512, but so far only in CLI, not in WinBox.
I think it’s just added the SHA256 CBC 256, But it’s beta?
Whole v7 is beta, only it’s not officially called that. ![]()
I kinda Figure this out and have a lot of problems with OVPN on 7.1.1 +
But other than that for simple usage, it’s pretty much stable, But not optimized
Thanks for all the replies guys I appreciate your help. I hope you have a good day/evening.
