RB433 AH and XR2 mini with antenna 15 dbi does not broadcast more than 100 meters.
i used :
POE 24V
and this cable
and this
so where is the problem and what solution
i used :
POE 24V
and this cable
and this
What is your terrain like? Do you have clear LOS all the way to the other end?
What hardware have you tried receiving with @ 100m? Radio & antenna.
Did you lower transmit power (card rates) for the xr2?
Have you tried another antenna?
Have you tried another radio?
Have you tried another pigtail/jumper cable?
There’s really no other reason for it not to work.
who is the client device? if that’s a notebook or a pda, then this is no surprise, they have small antennas and weak transmitters.
