iceblue
September 20, 2010, 3:11pm
1
Personal good day, I have never had a problem with the MK and I can not solve. I have built machines that play the role of proxy and other ERP. When I try to access these machines being on the switch and if not I’m on the internet and set up a dstnat, it works normally.
Both the machine as the proxy work with ERP IP/30 totally different from the ip’s that the machines are using the switch, however, the routes are configured on the IP> Route. Anyone know what might be happening?
Thank you all.
fewi
September 20, 2010, 3:22pm
2
/ip address print
/ip route print
/ip firewall export
From your post I’m not sure what situation works and what doesn’t. You can access the servers from the Internet but not from the LAN, or vice versa?
iceblue
September 20, 2010, 3:38pm
3
[quote=“fewi”]
/ip address print
/ip route print
/ip firewall export
Exactly, the RB1100 with 4.1 MK routes to the server if the package comes from WAN interfaces but not do the same if and LAN. Know what can be?
Thank you.
fewi
September 20, 2010, 3:40pm
4
Are you accessing the server by its public (NAT’d) or private IP address?
I’m guessing wildly here - please post the output of the commands I posted. A network diagram is a good start, but the actual router configuration is just as valuable to see.
iceblue
September 20, 2010, 5:17pm
5
fewi:
I am accessing the private and public IP, I have access by two ways.
ip address print
1 ;;; Sequencia 1
172.246.200.1/30 172.246.200.0 172.246.200.3 CLT
2 172.246.200.5/30 172.246.200.4 172.246.200.7 CLT
3 172.246.200.9/30 172.246.200.8 172.246.200.11 CLT
4 172.246.200.13/30 172.246.200.12 172.246.200.15 CLT
5 172.246.200.17/30 172.246.200.16 172.246.200.19 CLT
6 172.246.200.21/30 172.246.200.20 172.246.200.23 CLT
7 172.246.200.25/30 172.246.200.24 172.246.200.27 CLT
8 172.246.200.29/30 172.246.200.28 172.246.200.31 CLT
9 172.246.200.37/30 172.246.200.36 172.246.200.39 CLT
10 172.246.200.41/30 172.246.200.40 172.246.200.43 CLT
11 172.246.200.45/30 172.246.200.44 172.246.200.47 CLT
12 172.246.200.49/30 172.246.200.48 172.246.200.51 CLT
13 172.246.200.53/30 172.246.200.52 172.246.200.55 CLT
14 172.246.200.57/30 172.246.200.56 172.246.200.59 CLT
15 172.246.200.61/30 172.246.200.60 172.246.200.63 CLT
192 172.30.219.25/30 172.30.219.24 172.30.219.27 ether5 (ERP)
262 10.255.255.1/30 10.255.255.0 10.255.255.3 ether4 > (PROXY)
326 D xxx.xxx.xxx.xxx/32 xxx.xxx.xxx.xxx 0.0.0.0 adsl_ether7 >
327 D xxx.xxx.xxx.xxx/32 xxx.xxx.xxx.xxx 0.0.0.0 adsl_ether6 >
328 D xxx.xxx.xxx.xxx/32 xxx.xxx.xxx.xxx 0.0.0.0 adsl_ether8 >
/IP ROUTE PRINT
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 adsl_ether7 1
1 X S 0.0.0.0/0 adsl_ether6 1
2 X S 0.0.0.0/0 adsl_ether7 1
3 X S 0.0.0.0/0 adsl_ether8 1
4 A S ;;; Link0
5 A S ;;; Link1
6 A S ;;; Link2
7 X S 0.0.0.0/0 adsl_ether6 1
8 X S 0.0.0.0/0 adsl_ether7 1
9 X S 0.0.0.0/0 adsl_ether8 1
10 X S 0.0.0.0/0 adsl_ether8 1
11 X S 0.0.0.0/0 adsl_ether7 1
12 A S ;;; Link0
13 S ;;; Link1
0.0.0.0/0 adsl_ether7 2
14 S ;;; Link2
0.0.0.0/0 adsl_ether8 3
15 X S 0.0.0.0/0 adsl_ether6 1
16 X S 0.0.0.0/0 adsl_ether7 2
17 X S 0.0.0.0/0 adsl_ether8 3
18 ADC 10.255.255.0/30 10.255.255.1 ether4 0 (PROXY)
21 ADC 172.30.219.24/30 172.30.219.25 ether5 0 (ERP)
22 ADC 172.246.200.0/30 172.246.200.1 CLT 0
23 ADC 172.246.200.4/30 172.246.200.5 CLT 0
24 ADC 172.246.200.8/30 172.246.200.9 CLT 0
25 ADC 172.246.200.12/30 172.246.200.13 CLT 0
26 ADC 172.246.200.16/30 172.246.200.17 CLT 0
27 ADC 172.246.200.20/30 172.246.200.21 CLT 0
28 ADC 172.246.200.24/30 172.246.200.25 CLT 0
29 ADC 172.246.200.28/30 172.246.200.29 CLT 0
30 ADC 172.246.200.32/30 172.246.200.33 CLT 0
31 ADC 172.246.200.36/30 172.246.200.37 CLT 0
32 ADC 172.246.200.40/30 172.246.200.41 CLT 0
33 ADC 172.246.200.44/30 172.246.200.45 CLT 0
34 ADC 172.246.200.48/30 172.246.200.49 CLT 0
35 ADC 172.246.200.52/30 172.246.200.53 CLT 0
The firewall is disabled for all tests.
Tanks!
fewi
September 20, 2010, 5:54pm
6
Based on that internal access should be working just fine.
Sorry, I don’t know what your problem is.
iceblue
September 20, 2010, 6:29pm
7
Thanks. I spent the same configuration that has at RB for a PC-MK and everything worked normally. The only thing the PC-MK is no bonding. If I find solution, post here for everyone.
iceblue
September 24, 2010, 2:36pm
8
I disabled bonding, and all functions were ok. Anyone know what might be happening? that the bonding “alb” I can not drive internally?
