Does pptp-client interface auto start?
I am trying to setup a pptp tunnel between to RB’s, and am setting up an interface called “tunnel” on the client. The interface is a pptp-client. (not dial on demand)
I THOUGHT that I would have to start the tunnel manually (somehow), and use netwatch to restart it if the tunnel goes down.
However, shortly after creating the interface I see it starting to attempt connections. Is this normal? Do pptp-client interfaces just auto-start and keep trying forever to connect?
Yes, it’s normal behavior. You don’t need to monitor the connection and restart it manually.
