Does RB 133c supports WDS-SLAVE
Does RB 133c supports WDS-SLAVE, since it only comes with Level 3 OS that doesnt support Mode as AP?
Thx
Good question - I wasn’t sure and I I just tried it. It does - WDS Slave works fine on a 133c!
Great, it works!!
Now try connecting a client to that wds slave.. It shouldn’t connect because a level 3 license only allows 1 wireless client/connection at a time..
-Gerard
:smiley: or else, nobody would buy Level 4 Licenses :laughing:
:wink: :wink:
Ooops. That is a slightly important detail. Thanks Gerard - glad I didn’t try it in the field.
