Does RB/493GPI support 3G modem ZTE MF626?
When I insert modem to usb port in RB/493GPI and power on, modem doesn’t detected by RB.
Who know does RB/493GPI support 3G modem ZTE MF626?
Versin of OS 5.14
Same problem here
USB port on rb493g does not have 5VDC power. You need to use usb power injector.
yes, this thing http://routerboard.com/product/99
some devices need it, some don’t. RB493 needs it
you could also use a powered USB hub
that won’t work.
it does, I have a RB493G and use a powered USB hub with a 3G modem.
nice! that’s a good hub, most hubs don’t work. can you share with us the hub model?
it was the cheapest one i could get my hands on from Big W (in Australia) it is Made by Zipp, and has no other identifying info except that is has 7 ports and is USB2.0 compliant.
