Hi
I worked somewhat with mikrotik products many years ago, and recently dusted off my RB1200 unit. I have upgraded to ver 6.37.1 (stable).
Everything is working as it should, but my download speed seems to cap at about 2.5-2.8 MB/s mark, With my previous router I easily had 4-4.5 MB/s.
I have disable UPnP and NAT-PMP, and done a manual portforward (both tcp and udp), which also seems to be working fine. All except for the lack of speed…
Any ideas ?
normis
December 1, 2016, 8:03am
2
post your config
how are you testing this speed? have you tried other methods?
Since this device can easily handle Gigabit WAN speeds, there must be an answer in 1. or 2.
Hi, and thanks for yor response. Please be patient, as I am somewhat rusty with both winbox and CLI.
(I hope I av XXX'out all "secret info", please inform me if I haven't)
[admin@MikroTik] > export compact
dec/01/2016 10:15:35 by RouterOS 6.37.1
software id = FSIY-CKVR
add name=bridge1
set [ find default-name=ether10 ] name=WAN
set [ find default-name=ether1 ] name=eth1_Mediacenter
set [ find default-name=ether2 ] master-port=eth1_Mediacenter name="eth2_Switch Link"
set [ find default-name=ether3 ] master-port=eth1_Mediacenter name="eth3_AP Loft"
set [ find default-name=ether4 ] master-port=eth1_Mediacenter name="eth4_AP Stue"
set [ find default-name=ether5 ] master-port=eth1_Mediacenter name=eth5_Rasplex
set [ find default-name=ether9 ] name="eth9_DHCP Server"
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des pfs-group=none
add name=dhcp ranges=10.0.0.100-10.0.0.200
add name="VPN Pool" ranges=172.16.1.2-172.16.1.50
add address-pool=dhcp disabled=no interface=bridge1 lease-time=5d name=dhcp1
/ppp profile
add dns-server=8.8.8.8,8.8.4.4 local-address=dhcp name=PPP_Profile_Morten only-one=no remote-address=dhcp
add bridge=bridge1 interface=eth1_Mediacenter
add bridge=bridge1 interface="eth9_DHCP Server"
/interface l2tp-server server
set default-profile=PPP_Profile_Morten enabled=yes ipsec-secret=XXX max-mru=1460 max-mtu=1460 use-ipsec=yes
add address=10.0.0.1/24 interface=bridge1 network=10.0.0.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=WAN use-peer-ntp=no
/ip dhcp-server lease
XXX
add address=10.0.0.0/24 dns-server=XXX domain=XXX gateway=10.0.0.1 netmask=24
ntp-server=129.240.2.6
add action=drop chain=input in-interface=WAN port=! protocol=tcp
add action=drop chain=input in-interface=WAN protocol=icmp
add action=masquerade chain=srcnat out-interface=WAN
add action=dst-nat chain=dstnat dst-port=XXX in-interface=WAN protocol=tcp to-addresses=10.0.0.10 to-ports=XXX
add action=dst-nat chain=dstnat dst-port=XXX in-interface=WAN protocol=udp to-addresses=10.0.0.10 to-ports=XXX
add action=accept chain=dstnat in-interface=all-ppp protocol=ipsec-esp
add action=accept chain=dstnat in-interface=all-ppp protocol=ipsec-ah
/ip ipsec peer
add address=0.0.0.0/0 enc-algorithm=3des exchange-mode=main-l2tp generate-policy=port-override secret=XXX
/ip proxy
set port=XXX
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
/ppp secret
add name=XXX password=XXX profile=PPP_Profile_Morten service=l2tp
/system clock
set time-zone-name=Europe/Oslo
/system ntp client
set enabled=yes primary-ntp=129.240.2.6
The speed is coming from utorrent (only legal files, of course ) Also all other utorrent settings are the same as with the other router.
I have now also tested the speed via speedtest.net , and got the following results: Ping 16ms - download 40.83 Mbps - upload 40.60 Mbps (these values correspond with my Internet service subscription)
