I installed a full chain ECC certificate to the router from Let’s Encrypt. It shows up in the Certificates window of WinBox with a key type of EC and a key size of secp384r1. But when I try to use it for the www-ssl service or SSTP server, I just get “connection reset” errors. Using an RSA certificate works fine.
Is this a limitation of RouterOS?
