Does RouterOS support Failover and load balancing
Hello
I am very new to Router OS. I am looking for a Router operating system that can support automatic WAN interface fail over and load balancing functionality.
  1. I would like to know if RouterOS can be configured to support automatic WAN interface fail over between 2 cellular modem interface? or for that matter any 2 WAN interfaces?
  2. I understand it is based on Linux Kernel 2.6. As a developer will I be able to develop an application that runs on RouterOS using the RouterOS API and standard C, C++ functions?
Shanakr
I you set two default routes with different costs and set the gateway check feature to ping then when the default becomes unavailable the second will begin being the active route.
I think you’ll have to talk to mikrotik if you want do develope for mikrotik. You can use the scripting or API features but the routeros software isn’t open source.
