I have a 1310nm single mode fiber connected to a 155M media converter on the telco side.
They have provided a 155M fiber-ethernet media converter but I’d like to terminate directly to the SFP port on my RB2011. Is the S-31DLC20D compatible with the 155M rate signal?
That Mikrotik module supports 1000Base-LX which is not what you need. What is the make/model of the media converter that the provider supplied?
The media converter on the other end is some generic thing: Shenzhen bc-optics co. BC-100DSO13-20
If the MikroTik doesn’t support 155M I’ll use this SFP Module:
http://www.fibertronics-store.com/SFP-Transceiver-Module-155Mbps-Singlemode-1310nm-20km-SFP-LX-SM-0120.htm
Yes - looks like the media converter is saying 100Base-FX but supports oddball fibers and the 155 speed.
Drop me an if you like email - I might be able to get you a used module cheaper than that price.
