I found a post from 2015 stating that the Microtik RB260GSP does not have STP. However, in other posts it said that it may come in the future via a firmware update. Did these routers ever get the STP?
Not STP, but RSTP on model CSS106-1G-4P-1S (RB260GSP v2) with SwitchOS version 2.13
Thanks! Does it have 24v PoE capability (auto/on) on all ports? I need to use this to power 2 Ubiquiti radios.
EDIT: All I can see in the description is where it says it has passive PoE in–not that it can generate a 24v out (in the description it says: “Passive PoE (PoE in), 11-30 V PoE in input Voltage”)
Out only on ports 2-5 and the out is the same voltage thet you porvide on power jack.
Passive = do nothing.
