I get nothing with “/ipv6/firewall/mangle add chain=* action=sniff-tzsp sniff-target= sniff-target-port=37008” in any chain. Does it work for anyone?
I have this rule in pre- and postrouting chains and its working; receiving a nice TZSP stream filled with IPv6 packets on the other end.
/ipv6 firewall mangle
add action=sniff-tzsp chain=prerouting in-interface=pppoe-out1 sniff-target=<ipv4> \
add action=sniff-tzsp chain=postrouting out-interface=pppoe-out1 sniff-target=<ipv4> \
I’m still running ROS7.7 so i can’t speak for newer versions though.
One thing that quite odd from my point of view is that i can only send to ipv4 addresses and not to ipv6 targets, but that’s true for sniff-tzsp in general. Lets hope Mikrotik fixes that with the general IPv6 overhaul currently ongoing.
Best
BTW. while we are on topic, you might find this small little tool quite useful, I have it in my setup to feed suricata with the data of the pppoe link.
I’m on 7.9.2 and cannot get it to stream. Same action in /ip/firewall/mangle works just fine.
Sounds like you might want to post a support ticket number in this thread soon (-;
Appears to work as expected in 7.10.2
