I have a RB532 as an AP and a RB112 as a client with 2.9.27.
During testing I used a CM9, SR2 and WLM54G.
With the SR2 in the RB532 and spacing set to 5Mhz with NSTREAM and POLLING ON I can get the CM9 and another SR2 to connect to the RB532 just fine.
The WLM54G will see the RB532 when doing a scan, but will not connect to it. I just keeps saying searching for network. (I’ve made sure NSTREAM and POLLING was turned on the client as well.)
Has anyone else got the WLM54G to connect and work using 5Mhz and 10Mhz spacing?
hi
i did not try the 5 and 10 mhz channels but we hat other troubles with those cards used in an accesspoint.
somtimes after a reboot or after changing config on those cards no or onle very few clients connect and those who connect have a very unstable connection.
after a few on /offs of the interface it works again - very strange
also the cards do not work on a 502 daughterboard
changed back to cm9 and r52 - no more voodoos
