Does Ubiquity SR71-12 supported????
I use 4.10 RouterOS, I just got my SR71-12 delivered, however it does not appear in the interfaces, doesn’t it supported or not?!
thanks
I use RB433AH
it should be recognized. check the system resource pci and send the support output file to support@mikrotik.com
thanks for the replay, also I didnt update the licence maybe it is the problem.
no it doesnt work, I even upgraded it to v5. I still dont see the card in interfaces nor in resorces/pci
any help?
If you don’t see card in resource pci then is hardware problem, try to change minipci slot.
Even is card don’t supported by driver is always see in pci resource if properly inserted in slot and not broken.
