maroon
1
Dear Mikrotik fans,
I’ve installed the usermanager on 2.9.31 and it’s working so smoothly, but
i’m a bit confused about some features.. since I got used on another RBS
(advanced) and I used to set for a customer a limit of 250mb/day with a
speed limit 64k/256k, so all I wanna know is to setup such packages for
some profiles on ppp/profile.
please any help would be appreciated
Regards,
Giepie
2
Hi maroon
I read somewhere that it is in the pipeline.
UM will have profiles ie preconfigured rate limits etc.
So if you create a new user, you wont have to type in the limitations etc, only select the 256/64 or 64 burst to 512 etc profiles.
This would be a GREAT feature for WISPs
Thats Great! Profiles for different types of customer is an excellent idea. Lets hope they leave room for customisable profiles too.
