Is the “bad” WDS repeating mode (sending every station everything, thus -50% speed with every connected station) active when setting wireless mode to WDS?
Or is it the same “transparent Layer 2 mode” like in Ubiquiti AirOS?
You can bridge the wds ports or you can route on them. If routed it transfers only desired traffic.
Sorry but this does not answer my question, because these things are done in wireless driver imho.
bump
Yes, WDS means “WDS repeating” if mode=“wds slave” is used. Then you get 50% reduction in throughput per hop.
But if mode=“station wds” is used, it allows you to add the WDS interface to a bridge if you so desire. It is a hack used in the early days of WIFI to add a wifi interface to a bridge. But with the new mode=“station bridge”, it is no longer desirable.
