Hi guys,
I’ve been to the shop today, I tried many Intel motherboard but
apparently mikrotik doesn’t support any motherboard intel motherboard
even old 945 and 946 chipset that works , ROS doesn’t detect its Intel Pro 10/100 onboard LAN.
What a shame, even I plug CF-to-IDE adapter or IDE hard disk it itself it doesn’t detect it.
Even Version 3.0 beta 9 doesn’t detect the IDE hard disk and nor the CF-to-IDE adapter…
what can we do about it? I like to make a router out of this board
Are you sure about that?
then why would I receive HDD NOT FOUND error message before installation?
I tested all available boards and either this error
or none detected onboard LAN,
and I need all ports I can get. including PCI and PCI-X slot to make my router
Are you sure about this?
I took my Mikrotik 2.9.43 CD to a computer shop and I bought a new memory, cdrom, ram,cpu and tried dozen of intel mainboard and it didn’t work. and it gives me NO HDD FOUND message !!!
can mikrotik officials confirm support of Intel G965 or Q965 board support ? if yes how to detect them?
also why intel vpro 10/100 is not detect at all as well?
