This is my script for monitor doh server and if not working, fallback to standards dns servers.
Can be scheduled each 2min ; when doh server will be working again, switchback again.
:global dohServer "https://dns.nextdns.io/__id__"
:global testDomain "free.fr"
:global currentDoh ""
:global dohAvailable true
:global dnsServers "\
1.1.1.1,\
8.8.8.8,\
185.222.222.222,\
9.9.9.9,\
1.0.0.1,\
8.8.4.4,\
45.11.45.11,\
149.112.112.112,\
2606:4700:4700::1111,\
2001:4860:4860::8888,\
2a09::,\
2620:fe::fe,\
2606:4700:4700::1001,\
2001:4860:4860::8844,\
2a11::,2620:fe::9"
# func to test doh server
:local testDohServerResolution do={
:local result [/tool fetch url="$dohServer/dns-query?name=$testDomain&type=A" mode=https check-certificate=no duration=3s output=user as-value]
:if ($result->"status" = "finished" && $result->"downloaded" > 0) do={
:return true
} else={
:return false
# get current doh server
:set currentDoh [/ip dns get use-doh-server]
# if doh server is used, test if is still working, if not, test it work now
:if ( $dohServer = $currentDoh ) do={
:log info "doh server configured: testing if working correctly..."
:set dohAvailable [$testDohServerResolution dohServer=$dohServer testDomain=$testDomain]
:if (!$dohAvailable) do={
:log error "doh server not working, switching to standard dns servers"
/ip dns set use-doh-server=""
/ip dns set servers="$dnsServers"
} else={
:log info "doh server is working, nothing to do"
} else={
:log info "doh server not configured: testing if it work now..."
:if ($dohAvailable) do={
:log warning "doh server is working, switching to doh server"
/ip dns set servers=""
/ip dns set use-doh-server="$dohServer"
} else={
:log error "doh server still not working, nothing to do"
