Domain resolution + local services
Not sure if this belongs in “Forwarding Protocols” section – if so, sorry!
I’m new to RouterOS, and some things that I’ve done for years with consumer hardware is proving to be difficult for me with RouterOS.
I have a main RouterOS rounter, doing all the normal things a SOHO router usually does. I have a number of local machines with various services, some used internally only and some that have NAT rules to allow external access. The problem I am having…
  • I have a domain mydomain.com, and a subdomain sub.mydomain.com with CNAME record pointing to a DDNS service, which points to the public IP of the router.
  • Machine A inside the network hosts a service on port X that needs to be externally accessible.
  • I have added a Firewall NAT rule for this:
    Chain: dstnat
    Protocol: TCP
    Dst. Port: X
    Action: dst-nat
    To Address: <A’s local address>
    To Ports: X
  • Connecting to A on port X from another local machine using A’s internal address works fine.
  • Connecting to A on port X from a remote machine using the subdomain works fine.
  • Connecting to A on port X from another local machine using the subdomain does not work.
  • The subdomain always resolves to the proper router public address.
What am I doing wrong?
The server A is in same subnet as the client right?
Are the dst-port and to-ports same? Then just add a static dns entry on Tik for the sub-domain pointing to the internal ip.
If ports are different, you’ll need to add src-nat nat rule for traffic from lan to lan. See “hairpin” for more details
RouterOS doesn’t do some things automatically. You need srcnat rule for packets going from LAN back to LAN:
add chain=srcnat src-address=<your LAN subnet> dst-address=<your LAN subnet> action=masquerade
Explanation what it does and why it’s necessary is at https://wiki.mikrotik.com/wiki/Hairpin_NAT.
Thanks, @Sob. I ended up finding the hairpin solution after posting this topic, and it does indeed work. However I would prefer to be able to log distinct local client IPs for the services running in the network.
@sebastia I like this idea, but I can see one problem: Different machines in my network (other than A) host different services. So it seems a local domain entry will not work as it can only point to one local IP.
http://forum.mikrotik.com/t/ros-hairpin-nat-preserving-origin-ip-for-log-purpose/128750/1
Awesome.
