Don't upgrading RB3011 to 6.34rc20
Hey guys,
ATTENTION:
Don’t upgrade RB3011 to 6.34rc20 - After reboot, the device is pingable but neither winbox/ssh/telnet are accessible.
Router config reset: Same issue
At the moment, i have no serial console cable to check router boot.. shi*
RC = release Candidate … (which I am thinking you know)
Can you let us know what happens when you get a console cable connected?
unfortunately I upgraded to this version and have this problem now. Is there a way to recover the access to config?
My last config backup is very old :frowning:
Best regards,
Karsten
I tried to login via serial cable but no luck. Even when I try to boot from Netinstall it says “TFTP Timeout..”
I’m able to write to CF Card via card reader.. is it possible to copy over the update and invoke the upgrade without access to the system?
I would be grateful for any help :frowning:
