we have faced the same problem on a 2.9.8 OS while the n-streme was enabled…kind of deauth. message appeared at the log screen and the wds link couldnt stay up for one one sec…disabling either encryption or n-streme would solve the problem.
It is not so easy to fix. Maybe the fix will be in v2.10.
For now you can use only one of the feature at the same time. Enable nstreme instead of compression if you want better throughput.
we could do that…
but only if we had a only MT network…
now if you enable nstreme… no other AP or laptops can connect…
with compression the AP negotiates to see if the other end supports compression, if not it will do it uncompressed…
so nstreme is only a option if you would put some negotiating of nstreme in MT
but it’s not there , so …
