I recently purchased a hAP ac2 and this is the first time I play with such a product. It would be great if someone could take a look at my configuration and tell me if I made any obvious mistakes or if you would have done anything differently.
[admin@MikroTik] > /export hide-sensitive
# mar/09/2021 17:23:56 by RouterOS 6.48.1
# software id = AQPZ-DUUH
# model = RouterBOARD D52G-5HacD2HnD-TC
# serial number = XXXXXXXXXXXX
add ingress-filtering=yes name=bridge1 vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-onlyn country=germany default-forwarding=no distance=indoors guard-interval=long installation=indoor mode=ap-bridge skip-dfs-channels=all ssid=WLAN-XXXXXX \
wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-onlyac channel-width=20/40/80mhz-XXXX country=germany default-forwarding=no distance=indoors guard-interval=long installation=indoor mode=ap-bridge skip-dfs-channels=\
all ssid=WLAN-XXXXXX wireless-protocol=802.11 wps-mode=disabled
/interface vlan
add interface=ether1 name=vlan2 vlan-id=32
add interface=ether1 name=vlan3 vlan-id=33
add interface=ether1 name=vlan4 vlan-id=36
add interface=ether1 name=vlan5 vlan-id=39
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=intranet supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=wlan1 name=management
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether2 pvid=32
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether3 pvid=33
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether4 pvid=36
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether5 pvid=39
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=vlan2 pvid=32
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=vlan3 pvid=33
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=vlan4 pvid=36
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=vlan5 pvid=39
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=wlan1 pvid=39
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=wlan2 pvid=39
set discover-interface-list=none
add interface=ether1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge1 network=192.168.88.0
/ip dhcp-client
add disabled=no interface=ether1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
/system leds settings
set all-leds-off=immediate
/system ntp client
set enabled=yes primary-ntp=192.168.30.1
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
I use ether1 as hybrid port, which is connected to my firewall.
It does not work without them.
ether2, ether3, ether4 and ether5 are supposed to be access ports with separate vlan ids and ether5 is supposed to be on the same vlan as the two wifi interfaces.
My configuration seems to be doing exactly what I want, at least as far as I can tell. I've read the entire thread you linked, but this configuration is the best I could come up with.
My management vlan is 11
I have a bridge and on the bridge vlan filtering is selected and pvid=1 the default.
ether1 - trunk port , all vlans running on this trunk
ether2 - pvid44 - access port on specific vlan (DIRECT link to secondary ISP)
ether3 - trunk port running vlan11, and two other vlans for testing and config purposes(simulating hooking up managed devices anywhere on my network)
ether4 pvid11 access port to access point in the room
ether5 pvid11 access port to pc
The ip address of the switch is on the management vlan11.
If it was a hapac, the only difference would be
adding WLANS to the bridge as ports and associated pvids.
Where exactly is the issue with my current configuration? Is it plain wrong or just not elegant? As I said earlier, it does seem to do exactly what I want.
