Double-click required for all forum links?
Is it just me, or do you also experience this:
I have to click every link/button TWICE in the forum for the page to reload or whatever I want to achieve. I do have this from several systems with different browsers.
Is this some micros**t-ish “embedded confirmation dialog”: Are you SURE you wanted to click here? :slight_smile:
Best regards,
Christian Meis
fine for me, though maybe Macs come with double click as the default :slight_smile:
Strange - but I have a spare mouse at hand, just in case the current one won’t survive today because of this :wink:
Best regards,
Christian Meis
The forums are definately hosed the past week - the images are only half loading, double clicks (2 SYNs) are required to get the pages to load, etc … I think squid proxy is broken or needs a reboot.
Sam
Same here. Somebody kick the box.
I thought it was just my laptop (winXP)…I have to click on everything twice to get it to come up.
I’m seeing the same thing here, but I did notice a pattern:
If the page successfully loads, it’s always on a new TCP connection (SYN, SYN/ACK, ACK, and go).
On the other hand, if the browser is attempting to re-use an established connection, it always seems to fail (hangs after I get a couple of ACKs from the proxy box). At least it does if the established connection has been idle for a bit.
Perhaps the conntrack timeout on the new proxy box is set too low?
–Eric
I have the same problem.. I have to click links twice otherwise it just sits and hangs and eventually the connection times out forcing me to refresh.
And I thought something was wrong with me :wink:
Christian
Nah cmit… Ditto here! Something’s stuffed again, and it’s still buggered as I type this…
same issues here double click helps, but not always …i have MSTSC access to quite a few differnt FAST lines around the country (all very differnt isps,locations) and it was the same on 3 connections i tried..
EDIT: the country being the usa
:frowning:
However - at the office (we are an ISP with MT as our edge) this problem does not occur. First click, up in a flash. Back home on BrightHouse, no go.
Same issue here and I am connecting with a mikrotik.
Double click and connection is extremely slow.
I think you are right about the squid.
We did some improvements, please try again …
fixed here! no more 2 click
i appreciate the forums @ any speed!
tks
Fine here, too!
Thanks, Normunds.
Best regards,
Christian Meis
And not only that - at least for the response time for the forum dropped dramatically. Something seems to have been speed up :wink:
Best regards,
Christian Meis
better software, less support emails, more forum answers :slight_smile:
Much better. :slight_smile:
