So, here’s an interesting question.
I have an RB951 that I purchased in a lot. The reset button has been broken off, and the ethernet ports are cooked (all of them).
I used the internal reset pad to reset it, so now I have an SSID of “Customer RB951” with a security key. I have googled, but cannot find the key. I also can’t connect with WPS, since the reset switch is gone. Can’t netinstall, since the ports are fried. ![]()
I just wanna play around with this one, make a repeater off another MikroTik and try some cool stuff. Does anyone have any idea what the key may be? Normis.. can you provide insight?
It makes the reset noise every boot, so I know it’s back to defaults. But it seems to not be loading the default config.
Thanks anyone for any help.
