I have a network as in the picture. I want to remove NAT from my mikrotik. I know NAT in the TP-LINK router cannot be removed. Is there is an way to remove NAT from my mikrotik? If yes, how, please explain with ros codes.
The double NAT is causing problems in the apps like viber and so on.
Waiting for replies.
Its like turning around in the circles. You are still asking the same things, but I have doubts if you know at least something about routing and networks.
If you have enough addresses from your isp, make bridge on your wan side and put the customer to this bridge and let him take one of those ip addresses.
Otherwise, replace his device by something you can manage - by mikrotik or by openwrt.
I would not suggest to dispose your own router to outside world just because your client has device that does not what you need.
