Hi All,
Been using Mikrotik routers for years at work but have always used Draytek modems with PPPOE pass through so the Mikrotik does the ISP authentication…
Now at home I have upgraded to Fibre and have to use the ISP supplied modem, while this modem does support bridge mode, if I set that up I loose my VOIP
from the ISP…
I have set up the modem to DMZ the Mikrotik 962UiGS-5HacT2HnT but how do I set up the firewall and NAT to forward to my NVR and also accept L2TP/IPSEC connections?
Wan IP is like 203.xxx.xxx.xxx
Modem lan is 176.0.0.1
Mikrotik ETH1 is 176.0.0.2
LAN is 192.168.1.0/24
Any Help Appreciated.
Cheers,
Neil.
