double pppoe wan with same remote ip
Hi All
I am having a strange problem wich is stopping me to create a double wan setup with separate per-ip traffic
I think that the problem is around the automatic default gateway to the remote ip of the 2 pppoe wan connections that is created with a “preferred source” value of one of the 2 pppoe connections.
If i make a static route to let’s say 91.198.22.70 (dyndns’s checkip) then it works ok (i can estabilish the connection to whatever wan i want)
but if i try to route an entire subnet to use the other wan instead of the active (with < distance) i can’t.
I’m proceeding as follows: i create a mangle to mark prerouting new connection with src-address the ip adress i want to drive to the other wan, with dst-address !my-my-entire-subnet, connection mark and pass-through active
i create another equal rule with another ip i want to do the same with on the src-address, mark connection and pass-through
then i create another mangle which takes the marked connections and mark the routing
in ip-routes i then create a new static route with that routing mark to the wan i want to use for those IPs
i think that should be enough? Is it the “same remote address on the 2 wan interfaces” the problem or it is my rules chain???
Can some kind soul help???
I reply to myself in a sort of self-reasoning thread. Everyone is invited to add some contribution though :wink:
The fact that the 2 wan are having the same remote ip-adress should not be a problem, as in any case, on the local pppoe interface we get 2 different IPs! The outside traffic should pass the same gateway ok, but it should forward it to the generating ip adress at our side so that is not my problem i’m afraid…
