Is is possible to have a double Q tagging?
Like :
+--------------+ vlan 10, 12 ---------------| MT |------------ vlan 2215 with +--------------+ vlan 10, 12 inside
And if it’s possible how do I do that? thx in advance
As in Q-in-Q tagging / VLAN-Tunneling (cisco)?
If so, I dont think it is possible, mainly because on a RB you cant set the MTU higher than 1502. For Q-in-Q tagging to work properly you need minimum of 1500+2+2. ie. 1500 for the ethernet frame, 2 for the VLAN tunnel, and 2 for the internal VLAN.
Regards,
Alex
The particular feature is implemented in RouterOS3.0 It will work ony with suitable interfaces with Q-in-Q driver support.
Thank you both for your replies.
I will test with version 3.x
Do the routerboard 532 have these drivers?
