Double route, automatic switching
I have RB951Ui-2HnD and I want to use two networks.
Network 1 = a VSAT connection via ethernet port 1
Network 2= a 3G usb modem(ppp)
I have bridged WLAN and Ethernet port 2-5 as my LAN, and this LAN will be routed through either ether 1 or ppp-out which ever is having internet access automatically. I added route for ether1 and ppp-out but it doesnt switch automatically to another when one is down. Please my OS version is 6.29
I need any guru in the house to help me out plsssssss am a newbie to mikrotik.
your decription of what you are trying to achieve is incomplete. Are you trying to make your setup work as failover or as load-balancer? Are there any additional criteria for traffic shaping ( protocol, destination, etc etc…)?
Thank you for your response, all I need is just a failover. my problem is that 3G usb modems have no static address. all failover examples i saw have to do with static address. I just want a case where once the VSAT link is down and the 3G modem is plugged, for the traffic to automatically flow via the 3G usb modem untill VSAT comes up and it switches over.
Try this:
/routing filter
add action=passthrough chain=dynamic-in disabled=no set-check-gateway=ping
