Doubt about License
Hello all, I have a doubt about licensing in mikrotik, I was running a server level 6 with about 700 users connected by PPPoE, but yesterday my old server had a problem on the motherboard and had to exchange it for another machine, but the in flash that another machine was level 5, but I’m all users running normally, around 700 users … the version is 4.11 … something has changed within the limits of PPPoE tunnels in this version? In version 4.11 is accepting more tunnels? Or must I upgrade license it? Thank you.
L5 is limited to 500 tunnels
http://wiki.mikrotik.com/wiki/License_levels
You can get flash or hard drive from your other machine which had L6 licence and put it in your new machine
Yes I know … but I’m using a level 5 with more than 500 tunnels usually just picked up the backup from the level 6 server and laoded, and runs fine with more than 500 tunnels… why I stayed with doubts and decided to ask about it here
EDIT: I have added a image from the server running…
EDIT 2: Image retired… thanks.
We will check if it’s a bug :slight_smile:
Not sure if you want it fixed, though
No, you can leave with bug, no hurry… hehe :laughing: … but as a precaution have already installed the flash disk with level 6 this morning, this flash with level 5 was kept as a backup… thanks… Just telling … yesterday afternoon I was with 710 users with this level 5…
I hope it will be like it was with BGP support in Level4 :smiley:
