Doubt of hardware to use - Duda de hardware a emplear
It is my first contact with this technology.
I have carried out the measurements and tests to determine the real connection needs of a point with low coverage to the provider’s antenna
Test inside home:
Download: 08,41 Mbps
Upload:155 Kbps
Latency: 52 ms
Exterior test of the house
Download: 05.05 Mbps
Upload: 02.06 Mbps
Latency: 51 ms
Test where the antenna will be installed
Download: 08.00 Mbps
Upload: 14.60 Mbps
Latency: 36 ms
Información Torre CELL ID: 39941385 - LAC 65000
LG PG 19 PARC 114 - MOTA, S/N. CAMBRE - A Coruña - Spain
ETRS89:43º17´41"N - 08º17´32.79" O
I have doubts about which hardware set:
KIT LHG 4G
Totolink N300RT
OR
AIR10-4G
My current situation is the need to provide my son with an internet connection. He has come out of a recent hospitalization and relative isolation is required. I can not spend more than necessary and the installation would be done by myself.
Es mi primer contacto con esta tecnologia.
He realizado las mediadas y pruebas para determinar necesidades reales de conexion un punto con con baja covertura a la antena del proveedor
Tengo la duda deque conjunto de hardware:
KIT LHG 4G
Totolink N300RT
Ó
AIR10-4G
