Hi, I have some doubts about this configuration example on wiki:
http://wiki.mikrotik.com/wiki/Dual_Setup_with_OSPF
Dual Setup with OSPF
From MikroTik Wiki
In this setup we will be connecting a PTP configuration using a Dual Setup and OSPF (Open Shortest Path First).
The requirements for this set up is to have a board that supports at least 02 radios.
If you would like to double the bandwidth and redundancy, take a look at this Tutorial with Dual Radios.The advantages for this setup are:
- Full Duplex
- Automatic Failover
- No delay of packets. The same set up utilizing N-Streme-Dual can cause delay, which can be a problem if you’re dealing with VoIP or applications that requires maximum response.
- This set up can make use of two radios at each end, so the availability becomes even more robust in case of a radio failure.
What does it mean?
wlan1 on radio 1 (192.168.10.1) is connected to wlan1 on radio 2 (192.168.10.2), right?
Is the communication bi-directional (within these two radios) or only way?
- “Full Duplex”: I understand if it’s something similar to “nstream dual mode”, right?
- “Automatic Failover”: why? If one of these wlan1,2 breaks the link goes down anyway, right?
- “This set up can make use of two radios at each end, so the availability becomes even more robust in case of a radio failure”: how if any link Awlan1-Bwlan1 or Awlan2-Bwlan2 is not bi-directional link?
Thanks.
