Hi all,
Does any one know if mikrotik 2.9.7 supports dwl520 v.E1 or TEW-228PI (Chipset RTL8180L) ? if yes, does it work as AP or only clients ?
Thanks,
Anderson
Hi all,
Thanks,
Anderson
your 2.9.7 is not supported by itself. i suggest upgrading
Hi normis,
What version should I upgrade to so it can support these pci´s ?
Thanks in advance,
Anderson
first, read the driver list above. if the card’s chipset is not there, there is little chance that it will work. even upgrade won’t help. if the chipset IS listed there, then upgrade to latest 2.9
