Doubts PCC
Personal’m with a doubt concerning the PCC. I have the system running 100%, I have no problem with the balancing, but I need to make an exit when a user a specific link and I can not.
The structure is as follows the user “talks” with the server by ip 172.16.0.1/30 Manager and Manager speak to the PCC via CrossOver Server by an IP 10.0.0.1/30 and the PCC will balancing the demands of the manager. How do I recognize the PCC’s application for a specific user and directs the user to link an “X”?
It is important to note that the user does not have direct access to the PCC, it must first pass through the Manager.
Personally, I gave a palliative solution to the problem. Another interface called the Balance on the switch, marked the departure of the customer is directed to the link …
Once I find a more “controllable” by doing this, I post here for everyone.
But thank you all!
PCC used for load balancing works by marking with routing marks. Routes then exist that fire on those routing marks. All you have to do is to either mark the connections to be exempted by PCC before PCC, and to include a check on those rules so that they only match connections or packets that do not already carry that mark, or to mark them later and override the mark applied by PCC.
